Results 1 to 10 of 18
Thread: 36lb LS2 injectors with pigtails
    Nov 2006
    Mesquite, TX
    Have a set of these looking to get them sold for $175 first person with some cash takes them
    Nov 2006
    Mesquite, TX
    bumping these back up....i know someone needs some injectors....they will carry you to 500ishrwhp
    Aug 2005
    houston TX
    will these fit on the truck intake and fuel rails
    03 1500HD 4x4 6.0 on 33"
    K&N intake, Pacesetter LT, 3" true dule orp, Magnaflow, Comp cam 237 242 .603 .609 112, Patriot Gold springs and Ti retainers, stock ported heads, ASP Underdrive pulley, 42# injectors, 160 tstat., 05 E-Fans, Nelson Fan Harnas, tb bybass, MSD wires, NGK tr55, Ported tb, Transgo HD2, yank 3200 conveter, HP tuners, Walbro 255, 4.56s
    Mar 2006
    Mesquite
    Can I get a close up of the copper strands so I can see if there's any corrosion? Also, would you just sell 7 of them? I have a bad wire so don't need the 8th one anyway. Can you post 360 degree pictures of each injector so I can decide which 7 I want? Will you take a post-dated personal check? I can send payment as soon as you send the injectors and I make sure they work ok for a few hundred miles. I don't want to be stranded somewhere. Oh and do these come with fuel rails? Also, I don't need the o-rings since I can use the ones off my stock injectors. So please tell me how much of a discount without the o-rings. Also, can you do a video of you blowing water through each one so I can be sure they work? Just label each one 1-8 so I know you're not just blowing through the same one. Oh, and there's a 30% chance or so that I'll get these so if you don't mind putting some vaseline on the o-rings (in case I decide to buy those too) I would appreciate it. I don't want them dry rotting before I get them.
    Thanks...
    Slimsilverado Guest
    Didnt I already buy these Virgil
    WOW that's a weird post by Moze.
    wichita falls, tx
    +1...and will the fit on truck intake and fuel rails???????????????????????
    Intro Radicalli's
    Birmingham, AL
    he must have gone back by the liquor store tonight
    01 Silverado
    mesquite tx
    meds kickin strong!
    ITS MATT SUCKA
    98 rcsb dd
    abosolutely nothin cept flo
    & Nelson Tune
    lookin for project
    bangbangskeetskeet: how big is it v?
    mean05: about 8''
    txarkitekt: I will drink you under the table!
    It's too bad too 'cause I was ready to send Virgil money even though I don't need the injectors 'til the story was told.
