Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 43
Thread: Cut Outs
    So Cal
    Cut Outs
    Any one know if cut outs were used for a long period of time if they would mess up the tunning in my truck
    2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
    So Cal
    So if i use cut outs for street racing is there any down side to using them?
    why would you want to run cut outs which are meant for racing all the time?
    Im think Tyler runs his alot....but Im not sure.
    Waco, TX
    just get electric cut out's, open and close them from a switch inside the truck. use them when ur racing and close them when ur cruisin
    Feb 2008
    Arizona
    do they really improve performance?
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    ff_jeff Guest
    I have heard different people say different things. I dont use them because they tend to leak. When they are closed you can hear the leak.
    College Station, TX
    Through a stock engine with bolt ons, manifolds, cats and a e-cutout behind it, I lost power. I also heard it leak. I guess it just depends on different flows/velocity of exhaust
    my cutout hinders my performance in the low end, yet probably isnt too destructive on my highend, just not anything noticable.
    I mainly use mine for fun as it really brings out the sound of a cammed truck!
    o and ive never heard any leaking from mine and its very used
    I didn't see any gain, but some loss of low end power, but it just sounds freaking awesome. Mine don't leak either, sometimes when I start it up, they leak so I just have to close them with the switch.
    naples fl
    your gona lose low end, maybe pick up some top end. i haven't really heard of anyone buying them as a performance thing, it just sounds good.
    01 GMC sclb d-max 2wd.
    2.2 60' 8.9 1/8th
