Hey Jay,
I've noticed during the cold days, the a/f ratio in my av is leaning out as well.
Of course it feels like it picked up 50hp.
Probably just making more power and needs more fuel.
just thought I'd share that,
allen
Hey Jay,
allen
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
Whew! Glad I'm not the only one! Mine feels the same way with gaining A LOT of power. I went to straight meth instead of 50/50 mix to try and keep it rich but there's still a small period of time where the AFR goes into the high 11's/low 12's but I'm seeing zero KR. Hopefully, I can make it back by to have it re-tuned with the cold weather......and get an inspection across the street!!!![]()
Amen to that...I'm coming up on an inspection myself.
the air is more dense... what allen said.. needs more fuel. afr is off because more oxygen can be saturated in cold air. need to add more fuel to get the ratio back right. My mustang was running so lean today I picked up a little detonation.. Stock tune at that.
02 Sierra... motorless for now.
02 SS.. stock bottom 4.8, 241's, 224-220/116+4, 918's and pushrods, front mount turbonetics 78mm, HKS GTII, TiAL, eBoost2, Yank PT3600, Performabuilt 60e, solid motor mounts. Tuned by me with HP Pro and LM2/AFX
what is a proper AFR range? i guess if im going to go FI i better start learning something about it...
It might also be that the ltrims are slightly positive during the warmer days (not sure why on each application/vehicle) and what happens is the pcm will add additional fuel under boost if the ltrims are positive when going from closed to open loop, PE mode.
Not mine though, it just got leaner.
AF recommendations:
Normal driving and semi agressive:
14 to 16:1 a/f ratio
Aggressive to WOT NA:
12.5 to 13.0:1
Aggressive to WOT full Boost:
11.5
The more you boost the engine, the richer I take it, possibly going as rich as 11.0 at 15psi, just my suggestion.
Nelson Performance
NP on Facebook
Youtube Channel
well im only planning on running about 6lbs for now.
i guess my list of things to get are
bigger injectors #42
walbro Intake 255
AFR guage
Boost guage
what is is a necessity?
Nelson Performance
NP on Facebook
Youtube Channel
I guess I need to start going WOT more to see if my A/F is being affected at all
Nelson Performance
NP on Facebook
Youtube Channel
