Results 1 to 9 of 9
Thread: For you guys with returnless fuel rails &corvette filters
    SOMO
    I am having some trouble finding a fuel fitting that I need for my swap, I am going with the corvette fuel filter and need to find the fitting that goes into the front side of it. I used my awesome MS paint skills to draw a picture of what I am needing (the red part). Thanks in advance
    [URL=http://imageshack.us][/
    Aug 2006
    just cut off the end piece from a factory fuel line, that's what I did. Or you can get a 12" or 16" piece that has 2 ends quick connect from the auto parts store, look in the help section. I have seen the dorman parts at every local auto parts place.
    The quick connect end goes into regulator, the other end is cut off with tube cutter and I used a 3/8 compression to AN fitting.
    86 C10 6.0/4l80e
    SOMO
    I tried to find it at o'reilly's and the guy there said that they couldn't even get it. And I have been to a couple salvage yards and haven't had any luck
    I already have my 3/8 to AN compression fitting to use once I find this part.
    Spiro, Oklahoma
    I found mine at O'reillys so I don't know why they couldn't order one for you.
    What I did was cut the fitting in two to use a rubber hose, If you just need half the fitting I could send you the end I didn't use if you can't find one close.
    1991 Silverado-L33 5.3L, 212/218 .557 .562 115+4, ASP under drive pulley,180* thermostat, 90mm truck intake w/ LS3 throttle body. Shoenfeld conversion headers and duel Flowmaster exhaust. Performabuilt LVL 1 transmission and 23-2500 stall converter.
    SOMO
    Quote Originally Posted by low91 View Post
    If it comes down to it I might have to do that, and do you know what the part number was for it?
    go to the dealership and ask a tech to do a factory flare on your line for you
    I am running braided line or I would do that.
    Spiro, Oklahoma
    The part number is 800-155, If you can't find one just let me know.
    street and performance
    Quote Originally Posted by scarbrow View Post
    [url=http://imageshack.us]cd[/
    Street and performance has a corvette to -6 adapter that i used
    SOMO
    Quote Originally Posted by lilfreddie View Post
    I don't know how you ever found it on the site, I couldn't
    One of the worst web pages I have ever been on.
    May 2004
    Call them, Mark will know what your looking for.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
