wider lobe separation = less performance???
what does the lobe separation modifies?? for example 224/224, .566"/.566" with 112 vs 115 lobe separation, will they perform the same? just the diff in the idle??? or what do they change?
thanks
06' Silverado RCSB 5.3L 4wd..
HID's Hi, Lows & Fogs
