Results 1 to 10 of 13
Thread: When to do P&P and 3 angle valve job?
    Feb 2008
    Arizona
    Im thinking about doing those mods to my truck cause I've heard that they help performance wise.. When should I do it? in a cam swap or when?
    Do they really help a lot? any advice? thanks
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    whenever you have the heads off, in my opinion you shouldn't get too crazy with port and valve sizes, the motor still needs velocity unless your going FI. Same applies with exhaust, people think you need some back pressure, wrong. You need velocity and you dont get that with a massive pipe, there can be a very fine line. EDIT: The velocity helps pull more air in.
    Feb 2008
    Arizona
    so, if im going N/A, shouldnt do that?
    Quote Originally Posted by Felix Arrizon View Post
    No you can do it, there is just a point where you hit too much, an average port and polish and 3 angle job won't get you near that
    Yeah man, you can do it--but I'd deck the heads slightly to bump CR a smidgen. The valve job and PnP will help clean them up and flow better. I say do it!
    Feb 2008
    Arizona
    "but I'd deck the heads slightly to bump CR a smidgen."
    What do you mean with that bro??
    Alright.. I might do PnP and 3 angle job in my cam swap... I'll put the pushrods and the valvesprings while I am at..
    he means machining the heads down just a little bit, it makes the combustion chamber just a wee bit smaller which bumps up your compression ratio
    you have a cam size in mind? this will help decide on what needs to be done, but by all means at lease have the heads milled enough to basically clean them up.
    Simple: 408 on steroids!
    single digits coming soon!
    Feb 2008
    Arizona
    Im thinking about the 224... what do you think?
    Feb 2008
    Arizona
    or 220 Im not sure about those two..
