What PSI should I run in my new Slicks?
So I have sold my E.T's to Ducky to help him hook that turbo truck up. With my tourqe off the line I had to step up to straight Hoosier slicks. So my question is I want them to wrinkle like BlueCajuns Avitar, but I also dont like my azz end moving around at the big end. What pressure should I run in these slicks for maximum traction and best 60' time?? I plan on upping my line shot to 100 to test out Red's rod bearing theory.. I really want to be running a forged 370 at the shootout and that will not happen unless Red is correct about rod bearings (my wife does not go for replacing working engines)!! .
- You may not post replies
- You may not edit your posts
