Results 1 to 3 of 3
Thread: Magnacharger 112 Pulley Swap
    Question Magnacharger 112 Pulley Swap
    Any Particular Pulley Puller I Need?theres Several.i Was Going To Sell The 112,but Im Going To See What I Can Get Out Of It First
    Im At 5-6psi,going For 7-8 With This Pulley.
    Will The Pulley Just Come Off After Nut Removed,since It Has A Key Notch??
    Unless You Can Do It Allen,ill Leave It To You
    MidnightRider Guest
    Quote Originally Posted by chevrolade View Post
    no you have to use a pully puller and you will need a tune posibly injectors
    Would You Happen To Know If It Is The 3 Claw Puller Or What Type Is It? Thanx Again
