Results 1 to 8 of 8
Thread: Witch is better
    Mar 2004
    I was just wondering witch shift kit is better? B+M or Trans Go? Or are they just the same?
    Apr 2004
    I have heard good about both kits. B+M has been around for a while I know but I also heard alot of people going with trans-go.
    Jan 2004
    ive installed both, and transo is a better quality kit and comes with MUCH better instructions.
    just my .02
    Dan
    Jun 2003
    well i can tell you that the person that built mine uses trans go exclusivly.
    04 supercrew 5.4 3 valve-magnaflow catback
    formerly 02denali 12.79@107
    Oct 2003
    LaPorte TX
    B&M is just a shift kit.
    Trans-go is a shift-kit, that fixes some issues that GM failed to change,
    but if you get the Trans-go
    get the HD kit.
    you will like it much better. and with it you can take out all of the Torque Management, after you get your trans built correctly.
    this is how I have mine set up. It's like night and day.
    very fun to drive.
    02 Denali has they same trans as I do.
    1999 Pewter Z28
    Sold - 2001 Onyx Black Silverado Stepside "Thunder"
    Sep 2003
    picayune, ms
    i didn't know they made a HD transgo kit. So when you install it, can you adjust how much TQM you want or is it all or nothing?
    01 ecsb stepside. best 1/4 14.6 at 92 mph.
    Oct 2003
    LaPorte TX
    the torque management is removed with Edit.
    your just able to remove all of it with this shift kit.
    I wouldnt recommend removing all of it with the other shift kits.
    the HD Kit is about $130
    1999 Pewter Z28
    Mar 2004
    I wouldnt recommend removing all of it with the other shift kits[/b]
    When you say you can remove the torque managment by Edit, do you mean by programing or just with the shift kit?
