Results 1 to 10 of 13
Thread: Gears...
    Malvern, AR
    Gears...
    I been thinkin about it and i'm pretty much gonna go through with it anyways but, how much with swappin to some 4.10s from 3.42s cut my gas mileage??
    99 GMC 5.3 RCSS, K&N, E-Fans, Headman Shorties, Built 4L60E, 220/220 .581/.581 112, 80mmm TB, Nelson Tuned
    wichita falls, tx
    how much u drive on the hwy?
    i went from 3.42 to 3.90 and it wasnt much of a difference in mpg
    but gets off the line much better now
    Intro Radicalli's
    ff_jeff Guest
    You should not see a big difference. Some say you get a little better MPG because engine is in a better spot on the powerband. I wouldnt worry about it much though.
    Malvern, AR
    run it every day. 34 miles to work and 34 miles back home. i'll prolly get a one of those hydrogen kits in the near future anyways. maybe that'll bump it back up if i lose very much
    Malvern, AR
    motive or richmond gears?? what do you suggest?
    ff_jeff Guest
    I suggest Rons machine service... here---> eBay Motors: GM 8.6 CHEVY 10 BOLT 4.11 RING AND PINION INSTALL PKG (item 330263169396 end time Oct-17-08 05:58:54 PDT)
    Comes with install kit, or look at his other auctions for just the gears for $119
    Slimsilverado Guest
    thats really cheap i would be a lil concerned where they are made at. Might be Chinese knock off there Jeff. Both Richmond and Motive make great gears that will last forever
    ff_jeff Guest
    They are made there in house I believe. Allot of people have used rons. I havent heard anything bad about them yet.
    Crossett,Ar
    I run a 4.10 in mine and i am averagein over 20 mpg running between 75 and 80.
    wichita falls, tx
    i use them...no prblems yet
    Intro Radicalli's
