wow,
I have Got the new tune in which is great by the way, Allen.![]()
The new cam, springs and rods in and I have about 400 miles on it since the swap.
wow,
Hey James my truck is hitting the rev limiter too and allen is sending me another tune with a higher rev limit. I'm hitting it at 5800rpms. By the way you going to the valley tonight? I'm leaving work at 4:30?
2015 GMC Sierra RCSB Z71 5.3
I'll check your file, I thought i had flatops high enough, i guess not, i'll let you know, at least that will take care of the rev limiter.
thanks,
allen
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
With Allens tune and cam It's pulling Hard to 6000.
Allens tune is great,
I think my rev limiter is high enough, at wot it's great its just when the truck decides to drop down 2 gears and I'm in 2nd reved right out which is what I really don't want to be anyway.
I'm going to the track and dyno soon to see if i might need to upgrade my 99 injectors so I can get an update from you after that.![]()
Yeah, mine has that same issue at times, seems to drop in a lower gear than needed. Not sure if there is anything to fix that....Allen?
How did the track go? We'll have to get together sometime as i want to see your truck!
Andrew
Andrew
2001 Silverado 6.0 RCLB - Home Page - 4.8 to 6.0 Swap
Nelson Tune, Comp Cam XR265HR, Pacesetters, Hotchkis Sways, 3.42, Eaton Posi, Transgo, LS1 Fans, Magnaflow, Eagle 219's 18x9.5, Fold-a-cover
Thanks Allen for the update,![]()
Truck is shifting exactly how I would like.
Now to get it to the track.
keep us updated,
Nelson Performance
NP on Facebook
Youtube Channel
