Results 1 to 7 of 7
Thread: CBs
    CBs
    thinkin about puttin one in.... i fish and wheel up in oklahoma and don't get cell reception or nothin in some parts. so finding your friends can get a lil difficult and time consuming. anyone else on here have pics of how they did thiers if anyone has?
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
    Racoon Twp., PA
    Mounting on the bed behind the cab is the best way to obtain a equal range infront of you and behind you. If you mount 2 antennas, you can only plug one in because there is a certain distance that they have to be apart or you wont get proper functionality. Think its like 80 inches. If you mount on rear of truck, your range will be more infront of you than behind you.
    2013 CC 5.3
    81 C10 LS1 project
    well i'm plannin on mountin it on my tool box in the center of it. it's the kinda box that sits inside the bed. i wanna build a custom mount outta stainless or aluminum that brings it a couple inches back and up from the tool box
    Georgetown, SC
    Mine is just on the side of my tool box I think you can see it on my sig. and my cb is under the steering wheel closer to the console side of my dash.
    John
    Four by Four to the floor.
    well my tool box don't sit on my bed rails. it sets in the bed. so i wanna put it in the middle of it.
    Racoon Twp., PA
    Just make sure you have a good ground from the tool box to the frame or to the bed, a bad ground will fry your CB real quick.
    2013 CC 5.3
    81 C10 LS1 project
    Georgetown, SC
    I don't have any pictures of it but I had one that sat in the bed and I made a simple bracket with diamond plate to match the toolbox. It basically just bolted to the toolbox and the antenna mount just sat on the bracket, but you do have to have your box bolted down or else you won't have a ground. My bracket faced toward the tailgate cause it'll break your third brake light if it's on the other side (I guess that's common sense though)
    John
