It's dark out and I guess I had a point to prove, So here's my dirty bitch.
Nice setup! You have any problems with the PLX wideband? I can't get mine to read - not sure what I'm doing wrong.
looks pretty sweet to me
T-RAV99 GMC | 5.3 | Skinny White Guy Tuned
i actually had good luck with it for awile ,but ,it just started acting up .it reads 14.7 all the time .im thinking its the o2 .the wires are a little corroded ,up north here the salt beats up evrything.and thanks moze ,i would of liked to cleaned er up but it was spur of the moment ,ya know.make sure youre plugs are in correctly.ive read and heard of them being plugged in the wrong hole.call them.i know theyres an issue with them.
LIAR! you stole those photos I know it!
haha just kidding. Nice truck ramsey
thanks ducky .now i jusst gotta get the drop in it.i just dont have time to do it right now .busy season for both companies,construction and towing.if i stole em i wouldnt know how to post em.lol
Finally! Good job Rammy. what a set up! Looks freaking sweet..
