Results 1 to 10 of 11
Thread: 4.8 to 8.1
    4.8 to 8.1
    I have a 05 chevy with a 4.8 what would it take to put in a 8.1L
    ff_jeff Guest
    Lots of Gasoline.
    Jul 2007
    The Green hell a.k.a Canada
    Lots of Gasoline.
    lmao. That's about it.
    That would be tough. The 8100 was available in 2500HD and above because it requires either an Allison or the 6-speed manual. The Allison required the 2" OEM body lift that makes a major part of the difference between a 2500 and a 2500HD. I'm sure other GM transmissions mount to the 8100 so it may not be as hard as it sounds. Why do that? The 8100 is not a real power house although it makes good torque. I will make the truck very nose heavy and probably will not provide the performance gain you seek. There is also limited off the shelf performance parts for the 8100.
    MidnightRider Guest
    the 8.1 is not a LS based motor so there are not many mods you would be better of going 6.0 they can make more power anyways
    Jul 2007
    Quote Originally Posted by MidnightRider View Post
    Or even getting a 454 stroker from Texas-Speed, if he's got his heart set on cubes.
    Nov 2006
    Mesquite, TX
    funny thing is isnt the 6.0 about rated the same hp and torque as the 8.1 from the factory, i know the 6.0 is like 345/385ish
    Jul 2007
    Quote Originally Posted by mean05 View Post
    LQ9 = 345/380 hp/ftlbs 8.1=340/455 hp/ftlbs
    Not worth the severe weight gain....
    Nov 2006
    Mesquite, TX
    If You Were Really Smart You'd Go After The Ls2 Motor And Lose 140ish Lbs
    Alum LQ9 LOL jk
    There was that truck on TRUCKSTV that did the 8.1 swap kinda. The guy took two trucks, converted them into one. One was a half ton the other was a 2500 with the 8.1. Would be awesome if the 8.1 was ls based
