Results 1 to 9 of 9
Thread: why TBSS??????????
    Butler Ky
    why TBSS??????????
    Iwas wonderin about the tbss intakes and if they are better that a ls6 on a truck (for low end). Or are they just a different style ls6.
    The point im gettin at is that i have a 4wd and guys are saying they are loosing low end.. SO.... Is it worth it how much hp would u expect from ls6 or tbss. And what is the most u would pay for both?
    Any input would be great..
    First hand exp. from a 4wd would also be sweet!!!
    Thanks Guys
    -Nate
    76mm Front Mount, Yank PT3200, 6.0, Built 80E, Isky 215/215, Devils Own, Nitrous Express
    The TBSS intake is a 90mm intake is why some "very modded trucks" are going to it. You will lose low end torque with the car intake. With a 4x4 you want as much low end torque as you can get. Stick with the truck intake
    Butler Ky
    i just wonderin because i am gettin parts together for a heads and cam swap and was wondering if it would be a good thing to look into.
    also do yall think the tr 220 on a 112 would be to much on a 4wd daily driver
    thanks nate
    I personally don't know first hand but I know of alot of members in here that run that same cam for a DD.(edit: If I'm not mistaken, a majority have the 114LSA.) Is this a street application or mostly off-road? I wouldn't spend the money on the TBSS intake if I was you. Maybe some others will chime in on the cam.
    112 sounds pretty tight for a heavy DD and a 5.3. I'll defer to others' opinions.
    Butler Ky
    truck is a daily driver for now i bought just for a toy but the damn thing get better millage than my daily driver so it will be my daily driver untill i can find a nice civic for a good price (This is not easy with gas at 4.00)
    But no i dont 4wheel it at all just if i need it.
    Guys let me know on some cam specs.
    Talking
    Gotcha. What is this thread about? What was I saying? I'm just hypnotized by your avatar
    I'm sure the gay architect that likes to crap on himself will see this tomorrow and spec you out a nice cam...just remember his truck is slow and don't let him talk you into echo tips
    Jun 2007
    im pretty sure he will say 220/580ish with a 114 lsa.lol.
    Sep 2004
    Breaux Bridge, LA
    funny, i never lost anything down low with the ls6 intake.
    to the op, go with what you like.
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
