This is probably one of the best a/f meters I've used, and I've used them all!
BRAND NEW FAST dual a/f meter, never been used.
My original fast meter had an issue, so I sent it off and they replaced my broken one for a brand new meter!
The dual a/f meter also comes with the secondary 12' sensor cable.
This enables you to view two wideband readings at one time, on the same screen.
The kit also comes with, one lightly used wideband sensor (the one attached to the main cable). 2) Another wideband sensor that has about 3 hours on it 3) One brand new, never used wideband o2 sensor.
The main harness cable has been modified slightly, I installed a cig lighter adapter for easy hook up and you can see two yellow terminals, that was used for battery hookup on the dyno. Note, the main harness o2 sensor connector is missing a clip, but the o2 sensor connector stays in, it's still usable, I've been using it like this for months and no issues.
170402 - Dual a/f meter - Retail: $613.27
170408 - O2 sensor replacement: $119.93
170459 - Secondary cable - $50.13
New: over $900.00
Take it all for $550.
Also, buy this before I post my next sale; a practically brand new AutoTap Scanner, and I'll throw it in with the wideband purchase. You pay shipping.
Atap:
