Results 1 to 8 of 8
Thread: Torque Question
    SE Georgia
    Torque Question
    Intake Manifold Bolts (First Pass in Sequence) 5 N·m 44 lb in
    Intake Manifold Bolts (Final Pass in Sequence) 10 N·m 89 lb in
    Intake manifold is that big black thing that the tb mounts right? Reason I as is because I swear somewhere I read that it torques to 22 lb in and not 89?
    Tired ol' 5.7, 5.3 swap in progress
    Handle every stressful situation like a dog.
    If you can't eat it or hump it.
    Piss on it and walk away.
    22 in lb is finger tight. I think you were correct in the 1st part of your post.
    SE Georgia
    K just making sure didn't want to damage anything
    Hutto TX
    As long as you don't misread "ft" for "in"!! You will become a superstar with bolt extractor!
    1991 Silverado ECLB
    LM7-T56
    Mar 2006
    Quote Originally Posted by r6z4o6 View Post
    heh! bolt extractor superstar!! nice.. I doubt you will need to follow this like a fly to ****.. Just make sure they pass the "feel" test and you will be good to go.
    May 2004
    1. Install the intake manifold.
    2. Apply a 5 mm (0.20 inch) band of threadlock GM U.S. P/N 12345382, Canada P/N 10953489, or equivalent to the threads of the intake manifold bolts.
    3. Install the intake manifold bolts.
    4.1.Tighten the intake manifold bolts a first pass in sequence to 5 Nm (44 inch lbs.) .4.2.Tighten the intake manifold bolts a final pass in sequence to 10 Nm (89 inch lbs.) .
    Aaron, This is straight from the manual bro but the thread locker is up to you.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    SE Georgia
    Ill probley pass on the loctite no telling when I might want to take it apart..
    SOMO
    i think you might have read that the rocker arms are 22 ft lbs.
