Results 1 to 10 of 10
Thread: A/f Ratio?
    Question A/f Ratio?
    OK IM FINALLY GETTING MY WIDEBAND GAUGE!! SP WHAT ARE THE GOOD NUMBERS AND THE SCARY NUMBERS?? ITS ON MY 08' 4.8 112 RADIX.
    RITE NOW IM AT STOCK 5-6PSI,IM GOING TO DO THE PULLEY SWAP FOR 7-8LBS.
    AND YES IM ADDICTED TO BOOST
    Boost guys could tell you more but I'd say 12:1 or leaner would scare me.....but I'm not very brave.
    you should be in the 10/11 range in full boost. 14-15 cruising.. thats what mines at
    Spring, Texas
    Mid to low 11's while in boost and 14-15 while cruising as Ducky said. Anything in the high 11's low 12's while in boost is getting on the edge. Make sure you watch your KR as well.
    Jan 2006
    x < 11.5 under boost and 14.5-15.5 cruising.
    12 Sec. Club! SOLD
    SOLD***
    Nov 2006
    Mesquite, TX
    im with the 10.8-11.5 guys at WOT
    Mar 2006
    Quote Originally Posted by mean05 View Post
    +1
    I dont like seeing my N/A setup over 12.8-9
    Mar 2006
    Phoenix, AZ
    Good rule of thumb for a safe tune:
    10.8-11.2 for forced induction
    12.5-12.7 for N/A
    More aggressive numbers:
    11.5-11.7 for FI
    12.8-13.2 for N/A
    Someone posted some screenshots from the ZR-1 tune over on the EFILive forum, and it commands as rich as 10.4:1 when in boost. I believe the stock PE tables in our truck tunes command 10.8 or 10.9:1 on our N/A motors.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
    May 2004
    Here's the instruction to the A/F meter I use. At the bottom there's a chart for reference.
    http://www.fuelairspark.com/Instructions/170450.pdf
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    San Antonio, TX
    Sounds like you got your answer, if it's richer than 11.2, that's ok until you get up here,
    see you soon,
    allen
