Does Anyone Know Something About The 5 Speed Manual Like In The Rst Trucks, Or Heard Anything
99 silverado 6.0 scat rods,patriot heads,ls6 intake, 595 595 238 242 112 custom grind,tune built-4l65e 4500 stall 4-10 gear
their a tremec tko 500 I belive and they're pretty strong.
2005 rcsb silverado 4.8L, Full bolt ons, obx lt's, ory, comp xr265hr hi lift, Nitrous outlet plate kit, built 4l65e, J-H shift kit, 2500 stall,3.73 G80 , 3 inch spintech cat back, tuned by Rick at Synergy motorsports
is that tranny the same one that comes with the 4.3 v6?
2008 GMC Sierra 5.3
RCSB
K&N Intake,Flomaster Dump,3.73,g80
Comming soon :Cam ,Nelson Tune, LT Headers and the works.
what do you want to know? its not a tko 500, ita tremec 3450 which is only rated at 300 ft lbs of torque.
TTC: TREMEC Transmissions
single digit street truck
for build info
Yeah I believe it's the same as a v6 truck. Some t56's are only rated for 350 torque and it seems like they handle a lot more than that. would there be a chance it would be better than a 4l60e. cause a dont have 2g's for a trans
