I want to get a different t-stat and I've been lookin at the 160. Do you need anything else when doing this change..retune, e-fans, etc? Also what kind of performance gains were felt by anyone? Is the 180 better or worse?
Mike
2000 RCSB
'05 LS2 11.5:1 C.R. l K&N l LT's l Torquer V2 l PAC Springs l Manley 7.4's l 92mm TB l LS7 Lifters l Circle-D 3200 l P&P TB l ARP Rod Bolts l LS1 E-fans l Nelson 93 Tune l Brand-X 100 Shot l Walbro 255 l Duals w/ X and Magnapacks l Vette Servo l Transgo S.K. l 30K Cooler l Detroit Tru-Trac l Motive 4.30's l ARP Cap Studs l TA Girdle
I only saw a little temp change from the stock one, But I dont have efans. I run at about 200* now, befote at about 215*
I run at 179* - 181* with a 160* t stat. I have e fans and a 34" radiator. That is with 101* with the a/c on high.
jamest
12 Sec. Club! SOLD
SOLD***
I should be fine then not having e-fans? I'm guessing the 180 is almost pointless if a 160 runs about 15 degrees hotter, that would put the 180 at almost stock temp range....I'm about 200-205. I've heard of lower t-stats causing sludge build up, has anyone noticed any problems like that?
Mike
2000 RCSB
You should get it tuned for it for sure, and start lining up parts to do some e-fans. I don't think the coil in the stock clutch fan will engage correctly with the lower t-stat. So when you are ideling around it will run pretty much a normal (stock) temp because the clutch fan doesn't engage fully until that temp to cool it down, but when you are driving down the road it will be a good deal lower than stock temp because you are forcing air through the front.
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
well a 180 made no diff on mine
06' rcsb silverado H/C/I/N2O 5.3
