Results 1 to 3 of 3
Thread: Injectors
    Southern WI
    Injectors
    I got a buddy thats trying to sell me some Venom 24# injectors. They have about 8-10 min of run time on them and he wants $100 for the set of 8. I'm just curious if these are worth it, or from what I remember the stocker's for the 2000 silv. are 24#...that's what I read somewhere? Thanks for any help!
    Mike
    2000 RCSB
    '05 LS2 11.5:1 C.R. l K&N l LT's l Torquer V2 l PAC Springs l Manley 7.4's l 92mm TB l LS7 Lifters l Circle-D 3200 l P&P TB l ARP Rod Bolts l LS1 E-fans l Nelson 93 Tune l Brand-X 100 Shot l Walbro 255 l Duals w/ X and Magnapacks l Vette Servo l Transgo S.K. l 30K Cooler l Detroit Tru-Trac l Motive 4.30's l ARP Cap Studs l TA Girdle
    Jun 2007
    yeh theryre worth it ,but the stockers are 24-28 lb range.
    The Garage
    although that is a VERY good deal, those injectors cannot support a lot of power. You would pretty much be buying new "stock" injectors. Try to get a good idea of how much power you would like to make and buy injectors accordingly. For example: a Walbro 340 fuel pump and 44 lbs injectors can support over 500hp.
