Results 1 to 4 of 4
Thread: Vapor purge valve and 4L60 tailhousing
    Kentucky
    Couple of questions?
    1) the vapor purge valve on front of intake can we get rid of this or is it something needed? If I do keep it does it tie in to the return fuel line?
    2) My truck is extended cab and the truck I got my engine out of was a extended cab also. But I've measure the transmissions and the 03 tranmission is 1" longer than the older one. If my driveshaft won't fit would it work if I just switch the tailhousings from the older 96 to the newer 03?
    1996 GMC extended cab, 2003 5.3/auto
    Jul 2005
    You can use your existing 4l60e if you want.
    Use these parts
    If you want to install a GEn 3/4 engine in a 96-99 truck you can use the existing 4l60e by using this flexplate spacer
    http://www.crateenginedepot.com/store/LS1-Flexplate-Spacer-12563532-P1343C0.aspx
    and 6 of these longer bolts
    http://www.crateenginedepot.com/store/LS1-Flexplate-Spacer-Bolt-12563533-P1344C0.aspx
    With this flexplate from a GEn 3/4 truck that used a 4l80e trans
    http://www.crateenginedepot.com/store/LS1-Flexplate-12551367-P1342C0.aspx
    I would think that your existing driveshaft should work with the newer 5.3/60e combo.
    And no swapping tailstocks will not make any difference as its the outputshaft itself that will need to be swapped.
    Your 1996 trans is a 4l60e with a non removable bellhousing and stamped steel inspection pan. In late 1997 GM started using a bolt on bellhousing 60e case that surrounds the TCC 360° nad has a small 3" cover to attach the TC bolts. This case is very similar to the 60e's that are used behind the GEN 3/4 engines.
    I really dont think you will have any fitment problems with your driveshaft. Perhaps the 5.3 sits slightly more towards the rear of teh truck than the 350 does?
    You'll be able to tell once you get the engine in place.
    Goodluck
    peace
    Hog
    97 GMC 2wd RCSB 5.7, s10 2700 footstall, Hooker 24621hkr LT's , 2.5" cats dual 4"pipes exit B4 pass. side tire, custom driveshaft 3.42 G80 FIPK MAF descreen GM/Mercruiser Marine intake manifold 29lb LS2(EV6) injectors Ed Wright PCM(best mod), LT4 KM 14.8@94mph 2.007 4000lbs 122mph
    May 2004
    Plug the line at the canister with a vacuum cap and you'll have to delete the purge solenoid DTC's out of the PCM. The 03 should fit fine, you might have to move the transmission crossmember up a hole on the passenger side.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Aug 2024
    If you're considering a weight loss treatment, Saxenda from Canada is a popular option. This injectable medication is designed to help manage weight in adults with obesity or those with weight-related medical conditions. Saxenda works by helping control appetite, leading to reduced calorie intake and gradual weight loss. Many individuals have found it beneficial in achieving their weight loss goals. If you're looking to explore this treatment option, purchasing saxenda from canada can offer competitive pricing and reliable access, helping you begin your journey toward a healthier lifestyle.
