Results 1 to 10 of 22
Thread: Headers
    Feb 2008
    Mass
    Headers
    Ok so since i am getting headers soon (hopefully 2 weeks) im starting to look around alot more and ive come across two places....
    Pacesetter 2WD/4WD Truck Headers & Off Road Y Pipe i know all of you guys like this place, but i found some on summit for 40 bucks cheaper.....
    PaceSetter Performance 70-2265 - Pacesetter QuickTrip Long Tube Headers - summitracing.com and then with the y-pipe the total is 440 to the 480 at texas-speed, but the summit headers are painted
    2000 Silverado Ecsb 5.3 Z71. Work in progress...
    Hmmmm... how does this sound????
    Feb 2008
    Mass
    Thats a good deal, if hed be willing to ship up to mass.
    if that doesnt work out try this place New Era Performance
    Feb 2008
    Mass
    Well so much for headers, the 4wd in my truck is having problems so thats getting fixed first.....ddaammnn
    What problems is it having? The classic "Encoder Motor" problems?
    Feb 2008
    Arizona
    O.o sounds familiar to me... encoder motor problems too.. piece of ****!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Feb 2008
    Mass
    Well my 4wd light comes on alot, and i have heard this almost whirling noise coming from left side of my front end. When i took my brakes off last night i spun my axle, i could hear the noise coming from a metal box behind my shock....is that my transfer case that puts my front end into 4wd?
    If I am hearing you right, that ''box'' behind the shock is your front axle housing.
    The front axle half shafts bolt up to the housing. It is not uncommon for the seals at this juncture to leak. Have you noticed any moisture or leaking of fluids there? How does your fluid level in the front axle look?
    ...It is not uncommon for the seals at this juncture to leak. Have you noticed any moisture or leaking of fluids there? How does your fluid level in the front axle look?
    Yeah, I thought it could have been a leak from the get-go. With the amount of offroading you do and how much crap could potentially get in there to ruin stuff, it is no surprise something has gone wrong. Yeah, let someone look at it and see what the extent of the damage is....
