Results 1 to 2 of 2
Thread: Whats this worth?
    SE Georgia
    Whats this worth?
    Tired ol' 5.7, 5.3 swap in progress
    Handle every stressful situation like a dog.
    If you can't eat it or hump it.
    Piss on it and walk away.
    Well, it depends. You could buy that setup and then have the heads decked .030'' and get them back to a stockish CR (the 243 heads provide a 65 cc size, and the 862 heads have a 61 cc size). The Z06 heads (243) flow alot better, but it would be useful to have the Z06 intake to go along with it. And since you have a truck motor, you should try and get a higher lift cam to go with the components that will produce good high end power. If you do end up doing this, a 3000 stall will be required to utilize the newfound power up top. Without it, your truck will be a dog down low...
