Dreaded evaporator change
The title says it all.........My 97 evaporator has to be changed so I'd like to hear some tip or tricks you've guys tried. I'm going to take the dash loose, the steering column loose since it doesn't go down far enough with the bolts out and swing the dashboard over to the passenger seat and support it. I shouldn't have to disconnect the wiring on the driver side since I've aready tried this before. I know there's 1 bolt on the inside and 4 screws on the outside firewall and the a/c hoses and heater hoses that need to be removed before setting the whole blower/evaporator/ heater unit on the ground. If you guys know a faster way, please post it.
Thanks
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
- You may not post replies
- You may not edit your posts
