Results 1 to 2 of 2
Thread: filling engine with radiator fluid after replacing the water pump,thermostat,hoses
    Talking filling engine with radiator fluid after replacing the water pump,thermostat,hoses
    easy way to fill up the engine with coolant,use the upper radiator hose to fill up engine,pull it off radiator,use funnel and fill the engine up,also use the bottle up on passanger side if you have one ,it goes strait to motor,when filling up that way using either way,it will push all the air out if the engine up and out pushing bubbles out and filling the engine up with coolant ,either way works great,because the tstat is down lower on motor the air in motor bubbles upwards and escapes ,
    Ripon, CA
    vacuum fill works great also.
    2005 rcsb silverado 4.8L, Full bolt ons, obx lt's, ory, comp xr265hr hi lift, Nitrous outlet plate kit, built 4l65e, J-H shift kit, 2500 stall,3.73 G80 , 3 inch spintech cat back, tuned by Rick at Synergy motorsports
