Well now that I have swapped motors and added a turbo I need to part with this engine. it is basically a long block. I have a water pump, valve covers an intake that is from th Lq9 but not sure if it will work. Also have exhaust manifolds for it but no manifold bolts.
This pic is when it was in the truck.
First drag zeake - Putfile.com
I do NOT want to ship this motor.
I will take $500.00 for it. I do not want to consider less based on my chances of killing the Lq9 with the trick turbo setup.
