Results 1 to 10 of 30
Thread: electric fan kits
    electric fan kits
    who makes a great electric fan kit for my 2000 silverado let me know, thanks
    Im using some e-fans from an ls1 camaro with the nelson performance harness. Trick performance products which is a sponsor on here makes a real sick setup that looks awesome
    Feb 2008
    Mass
    low99 lemme kno if you do that setup cause i have a 2000 silverado too and it was one of the things im thinking about
    2000 Silverado Ecsb 5.3 Z71. Work in progress...
    Southeastern Wisconsin
    i have a 99 and i went with the ls1 fans like ducky did with the nelson harness, cheapest and easiest setup ive seen, i love the way they operate. Im just gonna up my alternator to the 145 because ive noticed sometimes at a stop light with the A/C on full blast and the stereo on it dips to like 12.8v so, no biggie but thats alot of strain on the battery. I spent a total of 200 on my setup, bolted it to the existing fan holes using the existing fan hardware, they work great, they are pretty quiet too.
    e fan kit
    well sounds great were do you go to the junk yard for fans,and off what year camaro and also you said the wiring harness is how much for that,and does it come with everything for kit and thermostat also ,let me know do want to do this set up for sure thanks guys
    28.500 in., 5.3L/323, GMC, 2000, Perma-Cool - summitracing.com
    This is what I have and it is super simple. Hook up power and ground and 1 ac wire and thats it. It works really well. My ac blows colder than it ever has and I have tested the crap out of it. I let my truck run for several hours while dragging logs around with not even a hint of over heating. No excess wires relays etc etc.
    i got my ls1 fans off of a 2001 camaro SS, they were 100 with shipping off of ebay, the nelson harness was like 100 with shipping. and then you have to get ur pcm programmed so that the pcm can control the fans. i like it. i havent seen any mpg gain or loss, because the motor seems to rev up a lot faster so i cant keep my foot out of it. On a good day in the city i saw like 2mpg more but other than that hwy im still around 19/17.5 and city seeing 10 to 14 so it just depends how much you want to spend and how you want them to work really. i have pictures if you want to see how they bolted up
    yes lets see pics
    Feb 2008
    Mass
    ya post some pics. and any performance gains besides revving faster?
    I put my fans in during the swap from 5.3 to 6 so I could not tell. Milage is suppose to be from 0.5 mpg to 3 mpg better. I can't tell.
