Results 1 to 4 of 4
Thread: harmonic balancer
    Feb 2006
    MIZZU
    Question harmonic balancer
    Hey all-
    I'm installing a 6.0 and a custom Nelson Perf. cam into the truck and have a few quick questions for those that have done this.
    The balancer on the 6.0 is bent, so I cannot re-use it thanks to the salvage yard for being so careful
    Can I use the balancer from the 5.3(it looks identical) or are they balanced to the specific engine?
    Also I know that the balancer is not keyed, so does it matter where you put it back on in relation to the crank?
    I wouldn't mind an aftermarket balancer if you guys can recommend a good one that doesn't cost too much......and do they come pre-balanced??
    Also any other advice for a cam and 6.0 upgrade install that you guys can think of feel free to throw it out.
    THANKS, TY
    1999 Silverado Z71 RCSB with 2006 LQ4 6.0, Comp Cams 220/220 581/581 115lsa, STS, methanol, Nelson street tune, 160* stat, 2006 E-fans, FLT 4L60. 12.53 @ 107 on 5psi
    San Marcos Texas
    The one from your 5.3 will work fine. They are zero balance since they mount without a key so no balance. It doesn't matter what position it is installed. Sorry Quick beat me to it!
    Feb 2006
    MIZZU
    ok thanks guys
    Get a 25% underdrive harmonic balancer pulley for it. Since you need a crank pulley, go ahead and do this simple mod. Need a new crank bolt too.
