Results 1 to 10 of 20
Thread: installing a cold air intake on my truck.
    Sallisaw OK
    while scanning i was seeing intake temps up to 160F so with the heat of summer coming i know i got to do something.
    so ive started the project today, what i have planned is to suck air in from behind the drivers side headlight. so far ive removed the second battery, (ill relocate it later on somehow somewhere).
    i still had the stock storage box that went in that spot so i am gonna use that to house the filter and run a short piece of that aluminum foil type dryer vent with the wire inside from the hole behind the headlight to the box. ill take some pics of what im doing tommorrow as i continue the work.
    is there any reason why i shouldnt use that dryer vent stuff for a 2 inch long area?
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
    Yeah, good idea. Any time you can lower your IATs on a blower, you are doing yourself some good. Post up pics when you get done.
    damn 160 degrees? I get pissed when it goes up to 110. So I just mash the throttle to get some meth in their haha
    Sallisaw OK
    this is my plan
    suck in the air from here
    use this as a housing for the filter
    6.6L 4l80e
    MY GARAGE
    Are you gunna cut the front out of the box?
    Sallisaw OK
    yeah im gonna cut a 4 inch hole and use that aluminum foil type of dryer vent with the wire inside it to connect the box to the hole.
    6.6L 4l80e
    MY GARAGE
    Mar 2006
    Mesquite
    Looks like it should work pretty well.
    Sallisaw OK
    im almost there, i need to get a 4" pipe and some couplings yet and ill be able to finish it.
    6.6L 4l80e
    MY GARAGE
    DBYRD Guest
    now for some black spray paint looks great almost like it could be a stock setup. guess if u swapped the engine bay around it would be come to think of it
    Good job Illya. I think it will work great!
