Results 1 to 9 of 9
Thread: cooling fan
    Feb 2008
    Question cooling fan
    I have a 02 2500 hd w/a 6l truck is 4wd and I do alot of towing from cars to boats and tractors.Has anyone swapped from the clutch fan to electric fans on these trucks.I know the fans will bolt up directly from gm but none of our 07-08 2500,s have the electric fans. Gm doesnt have them on the 2500,s yet.Just curious if towing in 100 degree weather in traffic would be a problem?Any suggestions would welcome.I can buy a complete gm set up for about 450.00
    Would work great you'd need the harness and tune to turn them on and off or just order a set of perma cools off summitracing.com
    Or get the stock ones off the 04 and up trucks...
    http://store.summitracing.com/partdetail.asp?part=PRM%2D19517&view=32&N=700+4294 838842+4294908216+4294840099
    Needs no wiring harness and has 3 wires to hook up. Nothing else to buy.
    Nov 2006
    Plano, TX
    As long as the truck is moving at least 40-mph the wind rush coming in through the grill is far more than *any* fan can provide, what you are worried about is fan CFM when towing hard at under 35-mph, like when you got your foot in it towing a very heavy trailer up a very steep grade, then fan CFM will be a critical factor. But honestly if you are doing that kind of towing then you should ditch the POS factory radiator for a real 2-row aluminum unit in the first place. I don't know the CFM of the GM silverado efans, but they are rated for towing a 8800-lb trailer on a 1/2-ton EC truck... Our efan kit moves 4200-CFM on high speed and the flex-a-lite 282's are 5500-CFM but dayum loud and pretty large afa efans go. Whichever efans you go with DO IT you would not believe the performance difference and you'll finally have COLD max a/c under 35-mph for once lol. PM me or Sprayed99 for more info, ours are on sale...
    Mr. P.
    BTW - don't forget you will need to upgrade your alternator to the big-case Delco 244 unit (145-amp) and longer belt, check eBay you can find new pull-offs for about $70-75.
    Apr 2005
    05 & up I think. My 04 didn't have them, had to get them off an 05 for mine.
    Gone, but not forgotten!
    Nov 2006
    Mesquite, TX
    Quote Originally Posted by SCIV View Post
    yes sir 05 and up...tyler just doesnt know what he is talking about
    Jul 2005
    Azle , Texas
    I have a 05 1500 HD 6.0L with a set of 05 1/2 ton fans (34") and a factory wiring Harness , never had a problem one .
    But be sure with the larger fans (34") to run a few fuses with them for safety sakes .
    FYI , There are several diagrams on the net for fan harnesses .
    Now what is a tune again?
    Comp Cam 54-412-11 , Int:265, 212, .522 , Exh: 271, 218, .529 , LSA 114 , Longtube , CAI (Vararam) , TransGo HD2 shift kit , tuned by me with EFILive
    Quote Originally Posted by use2bfo View Post
    I have a 05 1500 HD 6.0L with a set of 05 1/2 ton fans (34") and a factory wiring Harness , never had a problem one...
    My thoughts exactly...
