Results 1 to 4 of 4
Thread: Head bleed off hose?
    Well on my 6.0 swap I did away with the TB heater connections, and have the hose run from the head to the radiator. It is plumbed into it about 6" below the cap. I got to thinking, that coolant from the radiator will want to go into the hose, when all its for is air/vapor whater to come out, so question is, should I tee it into the overflow, right below the rad cap, or is it fine to have it where I do, I can add a picture if needed.
    Mar 2008
    Denver, Colorado
    i just blocked mine off. it goes no where and i am S/C have had no problem at all with it
    Ok, I just read on ls1 tech, that it shouldnt be blocked off, but then again, the ones that have theirs blocked havent had any problems that I know of.
    Big pine key, Florida Keys
    running them from ur head to ur radiator is the best way it keeps ur TB cooler too u do not need to T it into ur overflow, hope this helps good luck
    <a href=http://i137.photobucket.com/albums/q209/Rassele247/GavinsBannercopy.jpg target=_blank>http://i137.photobucket.com/albums/q...Bannercopy.jpg</a>
    05 Silverado cc LQ9, 220 220 .581/.581 114+1 LSA, Pacesetters with Ory, TBSS Intake w/ 90mm TB, Comp roller Lifters, LS7 1.80 rockers, LS1 Heads, Transgo HD2, Vette servo, 160 stat, custom 3inch exhaust, and Nelson Tuned:
    5400lbs- 13.62 at 100.46mph - Dynoed at 360rwhp - 375rwtq
