Results 1 to 6 of 6
Thread: part numbers for retainers, locks, valve seals
    Feb 2005
    San Antonio Tx
    need part numbers for some locks (32 needed?) retainers (16 needed?)...
    and valve seals... which ones?
    02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
    Oct 2005
    drinking your alcohol
    i got mine in a kit from texas speed.... check out the PRC kit they have.... i thinkit runs like 380
    there are cheaper ones im sure, but im a firm believer you get what you pay for
    DamnYankee: my nana failed
    Feb 2005
    San Antonio Tx
    well i already have the yellow springs... i just need the retainers, locks, and valve seals...
    Kansas
    https://www.patriot-performance.com/...ome.php?cat=51 check these guys out for locks and valve seals. they are good prices. Very good to deal with. I have the GM part number for the stock LS6 spring retainers around somewhere I'll see if I can find it.
    00' RCLB 2wd 5.3 AT: Wheatley Tune, Comp 265H, 706's milled .025, Comp PR's, 918's, Efans, s&b CAI, AEM lt's, magnaflow, ASP UDP, circle d 3200, 4.30's currently down awaiting built lq4
    Feb 2005
    San Antonio Tx
    https://www.patriot-performance.com/...&cat=51&page=1
    so just get 16 of these? they will work for the intake and exh?
    those ti retainers are pretty cheap... may have to get them as well...
    Yup, those are the ones. Yes, you need 16 of them. Titanium retainers are a MUST if running PRC springs.
