Results 1 to 7 of 7
Thread: My next project
    Feb 2008
    Ona, W.Va.
    My next project
    Texas Speed LS7 Short-block, forged crank, forged -3.8cc pistons
    Ported LS7 Heads
    Crane Cams 1449611 236 int./240 exh. , 0.630 int./0.630 exh. lift w/ 1.8:1 rockers
    Shaft mounted 1.8:1 rocker arms
    Head stud kit
    25% underdrive pulley/balancer
    62lbs/hr injectors
    LS7 intake w/ 90mm TB
    Head flow numbers:
    Lift__Int___Exh
    .2___168___119
    .3___244___179
    .4___306___211
    .5___347___224
    .6___378___235
    .7___392___246
    Going for a wild N/A set-up... lookin for 650RWHP.
    What do you guys think?
    Eric "The" Pyles
    14.06 @ 96mph / 9.02 @ 79mph
    302 RWHP/298 RWTQ
    Jan 2004
    That will be a beast! Id like to see that thing run! What are you going to do for the dry-sump oil? We thought about putting an LS7 into my brothers RX7 but decided on a H/C/N20 LS1 because of the dry sump problem, and the systems they do have are high dollar! Good luck with your project...you definitly have more room than an RX7 and that thing will scream!
    Feb 2008
    Ona, W.Va.
    Quote Originally Posted by LT1Truck View Post
    Well,the block from Texas Speed is going to allow me to run a wet sump system I think. If not, it's a $245 adder to upgrade to the LSX block and run whatever system I want.
    Eric "The" Pyles
    302 RWHP/298 RWTQ
    Feb 2008
    edmond, ok
    Sounds like a great set up. Keep us posted with pics and what not.
    07 GMC ccsb 1500 4x4, front replacment bumper, 285 70 r17 on 17" black helo max 6, Dual flowmasters dumped.
    I would stick with the dry sump--because that is how the LS7 was designed.
    Feb 2008
    Ona, W.Va.
    Well, I've moved to an LSX block at this point anyway. I can save right at $1,000 if I build the short block myself starting with a brand new LSX block at4.125" bore... 427 here I come!
    Eric "The" Pyles
    302 RWHP/298 RWTQ
    Jan 2007
    Burleson,TX
    that will be awesome...keep us posted
    06 silverado CC Volant CAI/ Corsa Sport exhaust
    dynatech supermaxx headers/cats
    LPE GT2-3 cam/ Comp 918's/ Rods
    Eaton LSD 3.73's
    IAT Shocks
    DANNY TRANNY w/2800 TCS billet verter
    275HP and 293TQ Pre Cam
    314HP and 303TQ post cam
