Results 1 to 7 of 7
Thread: LQ4 heads
    LQ4 heads
    Hey ive heard some LQ4's have LS6 heads on them...i have a 2004 LQ4 and was wondering if it had LS6 heads or what??? or a number i can look at on the head to tell which one i have?
    Big pine key, Florida Keys
    ya LQ4 came with 317 heads on them and the ls6 has 243 heads on them they flow the same but 317 heads have bigger cc chambers, hope this helps good luck
    <a href=http://i137.photobucket.com/albums/q209/Rassele247/GavinsBannercopy.jpg target=_blank>http://i137.photobucket.com/albums/q...Bannercopy.jpg</a>
    05 Silverado cc LQ9, 220 220 .581/.581 114+1 LSA, Pacesetters with Ory, TBSS Intake w/ 90mm TB, Comp roller Lifters, LS7 1.80 rockers, LS1 Heads, Transgo HD2, Vette servo, 160 stat, custom 3inch exhaust, and Nelson Tuned:
    5400lbs- 13.62 at 100.46mph - Dynoed at 360rwhp - 375rwtq
    sorry for high jack
    sorry for the highjack , but can you use 4.8 heads on a lq4-lq9 block ? also what about 4.8l intake can that be used on a 6.0l .
    Jan 2006
    It will choke the motor.
    Quote Originally Posted by redneck6 View Post
    12 Sec. Club! SOLD
    SOLD***
    what part
    the intake will or the heads ? i am planing a 6.0l swap and relly want to know what i can use off my 4.8l it is in a 06 rcsb 4x4 5speed ? if need i will start my own post . thank you thomas
    interesting
    sorry for being a noob , now least say we use 4.8l heads on a lq4 block that gives around a 11:1 cr , can we not mill the heads or open the cc up a lil , or use a thicker or thinner head gasket to get our cr down below 11:1 , and will i be able to use my accsors of my 4.8 on the 6.0l and headers and all the wonderfull bolt on stuff , so i should be able to get a short block and use every thing off my 4.8 on the 6.0l minus heads if we cant get the cr down .
    sorry for rabbling but i am trying to wrap my head around this fully as my truck just ran out of warrenty and i need more out of this truck as i will be buried in it . thank you thomas.
    geting some were i think
    i am thinking you would wanna lower the cr for drivablity sake as for 11:1 cr you would need to run high octane fuel above the 91 octane easily avaliable here , would you not , also would the pcm be able to keep up with that high of a cr , i would also think to fuel it would you would need to upgrade injectors i would also want more tourqe then hp and want it low in the power band , four wheeling and towing . so if i am headed in the right direction i would assume all i would need is a short block , and possabily heads ?
