Results 1 to 7 of 7
Thread: What Type Headers
    Mar 2008
    The Woodlands, TX
    What Type Headers
    I need some help picking out some mid length headers for my 4.8L any suggestions would be alot of help thanks I am looking to do this over the next 7 days.
    Spring, Texas
    What are your future plans for your truck? Do you eventually want to go with a turbo or supercharger? Or are you wanting to go with just motor and maybe some spray? It makes a difference in the stuff you will need.
    Mar 2008
    The Woodlands, TX
    I will be going with an rear mount STS later.
    Spring, Texas
    If you are going with an STS, then you don't want to get headers. I would look into getting a trans cooler, shift kit (may need to get built tranny later with STS), and definitely a Nelson tune for now.
    Jan 2007
    Burleson,TX
    keep your stock manifolds, they will hold the heat better...the money saved start buying hard parts that are known to break...i.e. G80 and tranny
    06 silverado CC Volant CAI/ Corsa Sport exhaust
    dynatech supermaxx headers/cats
    LPE GT2-3 cam/ Comp 918's/ Rods
    Eaton LSD 3.73's
    IAT Shocks
    DANNY TRANNY w/2800 TCS billet verter
    275HP and 293TQ Pre Cam
    314HP and 303TQ post cam
    College Station, TX
    IF you do want some headers dont go with the mid-lengths you might as well just spend the little extra $ and go with long tubes for the complete gain out of it
    Eh, go with some Pacesetter ceramic coated Long Tubes and wrap them. Make sure to wrap them BEFORE you put them on...
