Results 1 to 8 of 8
Thread: Amp Question
    College Station, TX
    Amp Question
    The Amp I have for sale in the for sale section...
    How would it sound hooked up to one Kicker 12"
    JW
    Heres the specs:
    4/3/2 channel amplifier
    55 watts RMS x 4 at 4 ohms
    65 watts RMS x 4 at 2 ohms
    130 watts RMS x 2 in bridged mode
    Tri-way capable (Tri-Way Crossover required)
    requires 10-gauge power and ground leads
    Bass Engine® features:
    * variable 30-400 Hz high-pass/low-pass crossovers, 12 dB/octave
    * rear channels have a subsonic filter at 15 Hz
    MOSFET power supply
    STAR Topology (minimizes internal noise and prevents ground interference)
    speaker- and preamp-level inputs
    preamp outputs
    oversized power and ground connections
    top mounted controls with cover
    blue power LED
    10-3/8"W x 2-1/2"H x 12-3/8"D
    May 2004
    I will sound ok at lower levels but it all depends on if the 12" sub is a 2 ohm or 4 ohm and what RMS vs Peak watts. I would use this type of amp for mids and highs then buy you a single channel mono amp to push the sub if your looking to hit hard. The amp you have will work though.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    College Station, TX
    There you go Ducky...The Sub is a 4 ohm too
    he is talking about this sub nitrous
    Kicker Comp 07C124 12" 4-ohm subwoofer at Crutchfield.com
    May 2004
    That's actually a pretty small sub and the amp would be ok at lower levels but would never reach the peak potential of the sub. Alpine isn't junk either. I like most of their equipment and have had great luck. I'm a Rockford Fosgate, Memphis and JL Audio man myself when it comes to power. I'm talking older amps, the newer stuff just isn't the same.
    97 GMC, 2002 LS6.
    Yeah, it will work ok and push it decently, but you won't be getting everything out of it... You should always go with a single channel (Mono) amp it push subs. I would use the current amp to push new door speakers and then get a Mono amp to push the sub.
    BOOM BOOM TSHH BOOM BOOM TSHH!!!!! thats propably what itll sound like.
    College Station, TX
    Yea Im just tryin to sell it on like 4 different forums and on tha streets fooool....So whoever buys it can do what they want with it haha
