A unique full Corsa system that I mocked up to work underneath my 1990 truck. This is a full Corsa exhaust from a 2004 5.3L Suburban. I had to cut the hangers off the system and put new hangers on it and make the pipe to connect to the intermediate pipes. The system has a dual 3" to single 3" y-pipe on it but if you have stock engines or even mild modified engine..you need to switch to a 2.5" dual inlet to single 3" y-pipe. This system produces absolutely no drone at all at freeway speeds.
The muffler is a 6.0L Sport.....part number 14263. The whole system is made of 304 Stainless steel and band clamped together for easy removal. I will supply instructions and mostly everything you need to put it on your truck. Since I've done all the work and spent a lot of time on it reconfiguring the front half of the pipes, I'm asking $450 + shipping unless you live outside the 48 states. I have sound clips but keep in mind this is on a heavily modified 383. Its much quieter on a mild 383 or 350. Only reason I'm selling is because the truck is no longer my daily driver and I'm going with true duals. This system is good for 500hp.
Thanks for looking. I can get pics if I start getting interest.
