Tach Question
How Can I Hook Up My Tach From Auto Meter?what Wire Do I Tap In?its Going On My 2000 Silverado
I'd hook it up like this:
Black wire to a good ground.
Red to 12 volt ignition.
White to a 12 volt dash lighting.
Green to Pin 10 white wire on the C2 connector.
Set wire on back of tach as a 4 cylinder - Clip the brown and orange wire and then insulate both ends.
Hope this helps.
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
- You may not post replies
- You may not edit your posts
