FastestTruckList changes
Well Greg threw out a good idea that I noticed would help with the FastestTruckList. His idea was to make sure it was stated what transmission each person was running. For instance he has a 4l80e in his 93 truck behind the LS1, and rightfully so it should be noted on the FTL that he has that.
SO, if you have an aftermarket transmission on your truck that was put in your truck and did NOT come from the factory (80e, 65e, t56, etc.) at the time you made the pass of the 1/4 or 1/8, please send me a pm so I can get it corrected for you. If you DONT have one, then dont send me a pm. Ill get this small change done here in the next week.
Thanks,
david
- You may not post replies
- You may not edit your posts
