Results 1 to 8 of 8
Thread: 93 octane tune ON!!!
    Feb 2008
    Arizona
    i just installed my PCM.. nelson's 93 octane!! i didnt have to do anything, just plug and play!! as soon as i connect my batery, i try it and my truck turned on right!! is that right? or i have to do the relearn process? the only thing is that my fan wont shut off.. i guess that as soon as i put the 160 thermostat, everything will be fine... all right guys... iam about to ride my truck!! talk to you in a second if i dont get pulled over by cops!! LOL!!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    if it turns right on then thats perfect. no need to do the relearn. The PCM will relearn itself though, so give it a week or so or a couple hundred miles before you start really noticing the difference
    ff_jeff Guest
    did you allready install the shift kit and servo's?
    Feb 2008
    Arizona
    yes sir, i already install them... nice shifting.. so, i dont get to feel the big difference till a week or so??? cause im leaving to rocky point tomorrow, and the sand racing attitude was on my mind really bad! actually, thats why i did this upgrades for...
    ff_jeff Guest
    go driving arround. 200 miles should be ok. but the longer the better. Oh and update your sig
    Jun 2007
    yeh itll slowly come on alittle harder as the week goes on.should see a nice diff immediately tho.its a good thing that u started right up .good luck.
    Feb 2008
    Arizona
    Thank you buds! i will drive around town to get this thing going... oh.. new sig! =)
    ff_jeff Guest
    You forgot to take off the Fast crap programmer. Also FYI TB spacer does nothing but make a funny noise. go get some new times.
