Originally Posted by
farmtruc
A few weeks ago the rearend in the Avalanche blew on a launch, I just ordered up a set of harder axles, full rebuild and a 3.73 gear set. The 4.10's were a bit too much, even with the tall tires.
If this doesn't hold, I'm dreading putting in a 3/4 ton rearend, that's more power taken away from the wheels, lol.
I'll post up some results at the track as soon as we're done.
allen ,what axles are you using ?its inevaatable ,so i though id get a set 2.plus ill feel alittle safer.im doing a bunch of changes within the next week and ill have it torn down.and yes i ordered all flt parts.lol. maybe a link if u have 1.thanks.good luck ,i think youlle like the 3.73s.
