Results 1 to 6 of 6
Thread: More gas for your money
    ff_jeff Guest
    My friend sent me this. He works for an oil corp. copy and paste it and send it to friends via email....................TIPS ON PUMPING GAS
    I don't know what you guys are
    paying for gasoline.... but here in California we are also paying higher,
    up to $4.00 per gallon. But my line of work is in petroleum for about 31
    years now, so here are some tricks to get more of your money's worth for
    every gallon..
    Here at the Kinder Morgan Pipeline where I work in San Jose , CA we
    deliver about 4 million gallons in a 24-hour period thru the pipeline. One day
    is diesel the next day is jet fuel, and gasoline, regular and premium
    grades. We have 34-storage tanks here with a total capacity of 16,800,000
    gallons.
    Only buy or fill up your car or truck in the early morning when the
    ground temperature is still cold. Remember that all service stations have their
    storage tanks buried below ground. The colder the ground the more
    dense the gasoline, when it gets warmer gasoline expands, so buying in the
    afternoon or in the evening....your gallon is not exactly a gallon. In
    the petroleum business, the specific gravity and the temperature of the
    gasoline, diesel and jet fuel, ethanol and other petroleum products plays
    an important role.
    A 1-degree rise in temperature is a big deal for this business. But
    the service stations do not have temperature compensation at the pumps.
    When you're filling up do not squeeze the trigger of the nozzle to a
    fast mode. If you look you will see that the trigger has three (3)stages:
    low, middle, and high. In slow mode you should be pumping on low speed, thereby
    minimizing the vapors that are created while you are pumping. All hoses at
    the pump have a vapor return. If you are pumping on the fast rate,
    some other liquid that goes to your tank becomes vapor. Those vapors are being
    sucked up and back into the underground storage tank so you're getting less
    worth for your money.
    One of the most important tips is
    to fill up when your gas tank is HALF FULL or HALF EMPTY. The reason for this
    is, the more gas you have in your tank the less air occupying its empty
    space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks
    have an internal floating roof. This roof serves as zero clearance between the
    gas and the atmosphere, so it minimizes the evaporation. Unlike service
    stations, here where I work, every truck that we load is temperature compensated
    so that every gallon is actually the exact amount.
    Another
    reminder, if there is a gasoline truck pumping into the storage tanks when you
    stop to buy gas, DO NOT fill up--most likely the gasoline is being stirred
    up as the gas is being delivered, and you might pick up some f the dirt that
    normally settles on the bottom. Hope this will help you get the most value
    for your money.
    DO SHARE THESE TIPS WITH OTHERS!
    WHERE TO BUY USA GAS, THIS IS
    VERY IMPORTANT TO KNOW. READ ON
    Gas rationing in the 80's worked even though we grumbled
    about it. It might even be good for us! The Saudis are boycotting American
    goods. We should return the favor.
    An interesting thought is to
    boycott their GAS.
    Every time you fill up the car, you can avoid putting more
    money into the coffers of Saudi Arabia. Just buy from gas companies that
    don't import their oil from the Saudis.
    Nothing is more frustrating than
    the feeling that every time I fill-up the tank, I am sending my money to people
    who are trying to kill me, my family, and my friends.
    I thought it might
    be interesting for you to know which oil companies are the best to buy gas from
    and which major companies import Middle Eastern oil.
    These companies
    import Middle Eastern oil:
    Shell...........................
    205,742,000 barrels
    Chevron/Texaco......... 144,332,000 barrels
    Exxon /Mobil............... 130,082,000 barrels
    Marathon/Speedway... 117,740,000 barrels
    Amoco.............................62,231,000 barrels
    Citgo gas is from
    South America, from a Dictator who hates Americans. If you do the math at
    $30/barrel, these imports amount to over $18 BILLION! (oil is now $90 - $100 a
    barrel
    Here are some large companies that do not import Middle Eastern oil:
    Sunoco...................0 barrels
    Conoco..................0
    barrels
    Sinclair.................0 barrels
    B P/Phillips............0
    barrels
    Hess.......................0 barrels
    ARC0.....................0
    barrels
    If you go to Sunoco.com, you will get a list of the station locations
    near you.
    All of this information is available from the Department of Energy
    and each is required to state where they get their oil and how much they are
    importing.
    But to have an impact, we need to reach literally millions of
    gas
    buyers.
    It's really simple to do.
    Now, don't wimp out at this
    point.... keep reading and I'll explain how simple it is to reach millions of
    people!!
    I'm sending this note to about thirty people. If each of you
    send it to at least ten more (30 x 10 = 300)...and those 300 send it to at
    least ten more (300 x 10 = 3,000) .. and so on, by the time the message reaches
    the sixth generation of people, we will have reached over THREE MILLION
    consumers !!!!!!! If those three million get excited and pass this on to
    ten friends each, then 30 million people will have been
    contacted!
    If it goes one level further, you guessed it ..... THREE HUND RED
    MILLION PEOPLE!!!
    Again, all you have to do is send this to 10 people. How
    long would all that take?
    nice thanks for those tips Jeff, also if you are getting gas and you have it set to stop when you are filled up, just stop there, don't try to get more out of it. when you pinch it to try an move the amount up, basically all your doing is charging your self more for nothing.
    SA, Texas
    Thanks Jeff!!!!!!!!!!
    Her name is A Meli-
    "If everything is under control, you are going too slow."- MA
    Feb 2008
    Vermont
    This is awesome info. Jeff, and it's about time a page like this was made! I say we all forward and "Blog" the ever living you know what out of this info. until it takes affect. I know I'm going to!
    There's no replacement for displacement.
    great info and thanks jeff, but what gas is everyone using? like from shell walmart cheveron whereever, the reason i ask is i buy 93 oct. and if i get it at a local convienant store is sux, or even wal mart, my truck jsut wont run good off it, seems shells octane is the rishess , guess why this is why it cost so damn much more
    Simple: 408 on steroids!
    single digits coming soon!
    Mar 2006
    Mesquite
    I get Shell or Exxon.
