Results 1 to 6 of 6
Thread: Question for farmtruc
    Mar 2004
    When I took my old pcm out I forgot to reprogram my factory settings out of myHPPIII into my old pcm will I hurt anything if I take the new tune out tomorrow so I can reprogram the old pcm so I can sell my HPPIII, I just don`t want to mess the new tune up.
    2003 black 2500HD xcsb, reflexxion cowl hood,305/70/16 MT baja claws, 16x8 ultra magnum wheels, magnaflow duals,K&N FIPK, NELSON`S TUNE!!!!!!!!!& #33;
    Sep 2003
    Mukilteo, Wa.
    Thanks for asking this question, I was wondering the same.
    '05 Tahoe 2WD 5.3
    Performance Mods: Nelson tune, 4" Volant Exhaust, Dynatech Full Header system, Volant Cold Air Intake, TB Bypass, 305/50R20 Eagle GT IIs
    Appearance Mods: 20x8.5 American Racing Torq-Thrust STs, Billet Emblem, Black Chrome Speed Grille, Removed running boards, door guards, fender caps and badges, and Silverstar lowbeams and fogs
    Cardomain Page> Click
    Sep 2003
    Cedar Park, TX
    I think you can swap pcm's as many times as you want. You should not have any problem except going through the key relearn each time. Allen will know for sure.
    '02 1500HD, 6.0L, magnacharger, 2000stall, custom magnaflow with electric cutout, E-fans, Nelson custom tune, Auburn LSD.
    '79 L82 vette, Summit 355, Dart Pro1 heads, Comp 274 cam, Holley TBI, Built TH350 with 2500stall
    '93 Blazer, full size 2dr 4x4, new project.....
    Mar 2004
    I just want to double check since I just put the new tune in, he said it would take a day or two for the new tune to be at its best.I figured I better take it back out now reprogram my old pcm and HPPIII before i let the new tune break in and I get used to all that new power.
    Mar 2004
    Never mind farmtruc, I did it this morning had no problem.
    San Antonio, TX
    sorry for the delay, too late to answer, LOL, once a pcm is programmed, you're good to go, you'll never loose the tune by removing it. The only way is if a dealer or some other tuner reflashes the pcm.
    thanks,
    allen
