Results 1 to 5 of 5
Thread: 5.3 to LS2?
    5.3 to LS2?
    I have tried search and can't find it.
    can this be done cheaply?
    if so how?
    I can't remember what all has to be changed. I know the reluctor wheel is differant can it be done without changing the wheel on the crank?
    If not forget it.
    San Marcos Texas
    You will have to change the wheel or mess with another computer attached to the one you have now so you can run an instrument cluster. You might need a trans computer too. I would change the wheel and get an extension for the cam sensor. You will have to change the knock sensors to the side of the block too. There might be other things I missed.
    Thanks by the way I appreciate the help.
    I need a distraction so I can stop thinking about putting an engine in my truck.
    San Marcos Texas
    Maybe you just need some more boost!
