Results 1 to 5 of 5
Thread: casting numbers
    Mar 2004
    Can anyone tell me what the following block casting number is from: 12561358?
    I just found out my heads are 862s and those are from 4.8L. I'm nervous my block is also from a 4.8L. Thanks in advance!!
    Oct 2003
    Widbey Island, WA
    is it an aluminum or cast iron block? 4.8/5.3 are cast -5.7 aluminum
    Dec 2003
    4.8 and 5.3 blocks are the same the only thing diffrent is the crank. I think there the same heads too
    old set up: 2002 chevy 5.3, procharger 12lbs boost, asm headers, ls1 edit, flames, 20inch budniks
    New Set up: 2004 chevy 5.3 ext cab, 12 inch twisted suspension lift, 36's, exhaust.
    future mods: 150-200 shot, ls1 edit, air intake, stall, 5.13 gears, 12s or bust
    Mar 2004
    This is a cast block. Then without opening up the engine, I won't know what I have...
    So the 4.8 and 5.3 use the same heads and block. The 6.0 uses the same crank as a 5.3?
    Dec 2003
    I think so i know that the 5.7 use the same crank. im almost sure they use the same crank just the bore size is diffrent
