Results 1 to 10 of 38
Thread: Huge Garage Sale
    91_bowtie Guest
    Huge Garage Sale
    I've decided to move on to another project, so I'm selling my garage full of parts. Feel free to make reasonable offers. The motor and tranny are coming out in the next week or so. If you want pics of anything, just let me know.
    2005 LQ9 6.0 block ~ 370ci
    Diamond -14.9cc dish pistons, Mahle rings, ARP head studs, ARP main studs, ARP rod bolts, 317 heads surfaced & valve job, GM 6.0 head gaskets, Eagle offset h-beam rods, Polished stock crank, LS6 valley cover conversion, custom Comp cam (KeithMcCord design), comp 918 springs, comp 7.4" pushrods, comp retainers. This motor only has 7k miles and 6k of them are just cruising to and from work N/A. All machine work was done by Don Burlington from Raytown, MO. He's very well known for his great LSx builds. This motor was built to handle some abuse. $3200
    Intercooled STS kit
    I purchased this kit used, without a turbo. I then bought a Precision 76gts with a .81 a/r. One of the pipes was crushed when I received it. I will have a new one made for the buyer. $3000
    2007 yukon 17" wheels... 400
    damn I soooo could have used that snow performance kit. good price on the 65e. im assuming the intercooler from the sts fit your tahoe?
    91_bowtie Guest
    Sorry. It went to a local guy earlier today.
    The kit is actually for a silverado. I just going to use the intecooler, wastegate, couplers, etc and fab a front mount with the gto manifolds.
    Sep 2006
    Coon Rapids, MN
    is the 4l60e for 4wd or 2wd??
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
    91_bowtie Guest
    Quote Originally Posted by 02CHEV View Post
    4wd
    Sep 2006
    Coon Rapids, MN
    any thing wrong with it. cause i am not having any good luck with my trans
    04 Grand Prix GTP
    soo the intercooler would fit my truck? would u be willing to part it from the turbo?
    Aug 2006
    McCurtain County, OK
    Are the GTO exhaust manifolds and the LQ9 exhaust manifolds the same?Would you do $40 shipped for one set?
    2004 ECSB Silverado LQ9 6.0L Superchips;14.0 @ 96: 4900lbs of Fun
    69 Chevelle Coupe LS1/A4 swap
    91_bowtie Guest
    sorry guys. I never got an email that there were replies to the thread.
    duckysbht... yes it would fit. No. I won't part it out.
    69chvelle... The manifolds are a little different in design. I paid 18 to ship the last set, so I'm not letting these go for anything less than 60 shipped. I have several sets of each design.
    sambo... This motor wasn't built for N/A use. I never had it on a dyno without the blower. It's a low compression motor built with the intent of running boost and putting over 700 to the wheels. I was planning on running 15 psi with the 76gts front mount. I'll make you a hell of a deal on the motor & sts kit, with a set of manifolds. I was just planning on using the intercooler, wastegate, couplers, etc, and just parting the rest.
    Nov 2004
    Pleasanton, TX
    Quote Originally Posted by 91_bowtie View Post
    Gotcha, 700 to the wheels would be I thought about the sts kit, but I would rather have a front mount, I could sell my Radix and 6.0 and still probably not be too bad off. Is that price on the motor firm? Your located in kanas right? I'm working up in colorado right now and kansas is right next door. Shoot me a pm and we can talk about this.
    2006 K1500 Vortec Max CCSB 6.0 4.10's, Nelson SD Tune, Trick Turbo kit T76 @ 10psi, 60lb/hr injectors, 4" duramax exhaust, snowmeth stage 2 kit, FLT Level 5 4L70E, Vig 2600, 40K trans cooler, 265/70/17 BFG All Terrains. 13.0 @ 102mph 1.8 60ft
