Results 1 to 5 of 5
Thread: pacesetter headers long tubes on a 4x4
    does anyone here have long tube pacesetter headers on a 99-02 chevy z71 ?
    i have been told they will fit, but pacesetter said they do not fit on 4x4
    Jun 2007
    yes they will.i had to cut my header back a couple inches to make the bend 4 exhaust to go over 2 pass side,but the headers have a long collctor were they merge,so thats y they probly say they wont work ,but im tellin ya its easy ,just grab a sawsaw and cut the header back 2-3 inches.pm me if u need advice.
    Thanks for the info, its not for me but i knew it could be done.
    Jun 2007
    o ya only the drivers side .pass is fine.
    o cool, thanks again ramsey
