im in the process of ordering gears and currently everything is stock in the rear end. My question is the stock a 10 bolt rear end or what?
1999 5.3 ex cab 3/5 drop, k&n CAI, BBK 80mm TB, Pace setter longtubes, 3" ory, hooker aero muffler, TS 224r cam w/112 lsa, comp cam 918 springs, TS chromoly pushrods, 180 degree thermostat, Nelson tune, 3 angle valve job, electric fans, 28x11.50 et streets
yes it is a 10 bolt, 99 and up with 30 spline axels......
10 bolt with 8.6 ring gear.
2006 K1500 Vortec Max CCSB 6.0 4.10's, Nelson SD Tune, Trick Turbo kit T76 @ 10psi, 60lb/hr injectors, 4" duramax exhaust, snowmeth stage 2 kit, FLT Level 5 4L70E, Vig 2600, 40K trans cooler, 265/70/17 BFG All Terrains. 13.0 @ 102mph 1.8 60ft
what gears you goin with and are you gonna get a true track.
I love my 4:10s in the avalanche..
