will these 6.2 s fit our applications if we built one /ordred one .llike a block and built it up too whatever specs we wanted .i mean is everything the same as ours ?if it was bought as a bare block and bolted our parts on too it so it would bolt in our trucks.or recip assembly even.im thinking if i bought 1 then put my s/c and bolts on it.seems like a good buils if so.
